Budget (including currency): 1500 - 2000 aud
Country: Australia
Games, programs or workloads that it will be used for: terraria, hosting terraria servers and some game dev
I am willing to wait for a better gpu
      AMD Ryzen 7 5700G 3.8 GHz 8-Core Processor
      Deepcool GAMMAXX GTE V2 64.5 CFM CPU Cooler
      MSI MAG B550M BAZOOKA Micro ATX AM4 Motherboard
      Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory
      Kingston NV1 1 TB M.2-2280 NVME Solid State Drive
      Gigabyte GeForce RTX 3070 8 GB EAGLE OC Video Card
      Corsair 4000D Airflow ATX Mid Tower Case
      Gigabyte P750GM 750 W 80+ Gold Certified Fully Modular ATX Power Supply
      Asus USB-AC53 NANO 802.11a/b/g/n/ac USB Type-A Wi-Fi Adapter
https://linustechtips.com/topic/1441629-first-build/
Looks good, already very overkill for playing terraria.
Only concern I have is the cooler. I've used that same model on my R5 3600 and in games it'd reach ~83 C with ambient temp around 27 C.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/1441629-first-build/#findComment-15469891
$11 overbudget, mostly because it seems like wifi is a requirement for you and wifi is an extra $70+ cost, in either more expensive motherboards or wifi cards. I woudn't make myself suffer through a USB wifi receiver. Just makes everything in life worse, trust me:
PCPartPicker Part List
CPU: Intel Core i5-12400F 2.5 GHz 6-Core Processor  ($249.00 @ Amazon Australia)
CPU Cooler: be quiet! Shadow Rock 3 CPU Cooler  ($69.00 @ PCCaseGear)
Motherboard: Gigabyte B660 GAMING X AX DDR4 ATX LGA1700 Motherboard  ($269.00 @ Umart)
Memory: Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($165.00 @ Umart)
Storage: Crucial P2 1 TB M.2-2280 NVME Solid State Drive  ($122.00 @ MSY Technology)
Video Card: ASRock Radeon RX 6800 XT 16 GB Phantom Gaming D OC Video Card  ($949.00 @ Mwave Australia)
Case: Phanteks Eclipse P300A Mesh ATX Mid Tower Case  ($89.00 @ PCCaseGear)
Power Supply: Gigabyte P850GM 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.00 @ Umart)
Total: $2011.00
Generated by PCPartPicker 2022-07-07 17:39 AEST+1000
If I were you I'd rather downgrade to a cheaper motherboard with no wifi, get a higher clocked 6800XT and buy yourself and ethernet cable and run it from you router to PC. You'll get a faster machine, more stable connection in games and it'll even be cheaper that wifi.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1441629-first-build/#findComment-15469980
