Budget (including currency): £1000-1500
Country: UK
Games, programs or workloads that it will be used for: Fortnite, Warzone, League of Legends, Tarkov
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I already have a monitor and peripherals from an old hand-me-down PC, so just the desktop.
Hi everyone forty here,
I'm currently living in the UK and looking for purchase a custom gaming PC, I think for now it's probably best to buy a pre-build and learn to make improvements along the way.
There are lots of sites out there that advertise gaming pcs, gaming computers and pc gaming but want to make sure I'm not steered away with fancy flash words. I have currently been looking for systems on the Cyberpower UK website https://www.cyberpowersystem.co.uk/category/gaming-pcs/ at the price range of about 1000-1500 pound.
Cyberpower in the UK seem to have really good warranties and service judging by their Trustpilot reviews, they seem to fit the bill for me, just wondering if anyone could suggest a custom system for me? I have looked at a bunch of preconfigured Intel and AMD systems, but just a little lost.
It would be great to hear back and maybe direct me to a specific system?
Tyty.
https://linustechtips.com/topic/1441476-first-gaming-pc-advice/
Country: UK
Tyty.
watch some gamers nexus prebuilt reviews
https://linustechtips.com/topic/1441476-first-gaming-pc-advice/#findComment-15468859
Look for Intel CPU and AMD Radeon GPU systems if you can. Prioritize Radeon GPU's, 6600XT's to 6750XT's. Ryzen and RTX are mainstream so you'll be paying inflated mainstream mass appeal prices.
At a quick glance, I woudn't spend any more than this on this type of system. Correct parts to allow you an upgrade down the road.
Looking at these prices tho, makes me wanna build PC's and sell them 🤑🤑🤑
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1441476-first-gaming-pc-advice/#findComment-15468927
