Budget (including currency): 1000 usd not including monitor
Country: United States
Games, programs or workloads that it will be used for: overwatch/2 BDO LOST ARK paladins dead by daylight. kof15 and samurai showdown
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): motherboard:msi ryzen 2nd and 3rd gen B450 TOMAHAWK MAX II
ram:Silicon Power Value Gaming DDR4 RAM 32GB (16GBx2) 3200MHz (PC4 25600)
power supply:EVGA 500 GD, 80+ GOLD 500W
cpu:AMD Ryzen™ 5 4500 6-Core, 12-Thread Unlocked Desktop Processor with Wraith Stealth Cooler
case:Corsair 4000D Airflow Tempered Glass Mid-Tower ATX
gpu:MSI Gaming AMD Radeon RX 6600 XT
storage:Silicon Power 1TB - NVMe M.2 PCIe Gen3x4 2280 SSD
is there anything im missing? or any switches on parts yall might reccomend? ive wanted to build a pc for a pretty long time
https://linustechtips.com/topic/1440655-first-pc/
I went micro-ATX to reduce the price a bit. You'll also definitely want a b550 motherboard for 5th gen Ryzen, especially for a new build.
https://pcpartpicker.com/list/rMMgzf
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($179.99 @ Amazon)
CPU Cooler: Vetroo V5 52 CFM CPU Cooler  ($34.99 @ Amazon)
Motherboard: Gigabyte B550M AORUS PRO-P Micro ATX AM4 Motherboard  ($129.99 @ Amazon)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($57.99 @ Amazon)
Storage: Silicon Power A60 1 TB M.2-2280 NVME Solid State Drive  ($69.98 @ Amazon)
Video Card: MSI Radeon RX 6600 XT 8 GB MECH 2X OC Video Card  ($344.99 @ Newegg)
Case: Lian Li LANCOOL 205M MicroATX Mid Tower Case  ($84.99 @ Amazon)
Power Supply: Corsair RM (2021) 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($94.99 @ Amazon)
$997.91
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
https://linustechtips.com/topic/1440655-first-pc/#findComment-15463010
1 hour ago, Ryuikko said:
Any reason why? The 4500 gets outclassed easily by the 12400f as well as having better upgradibility since am4 sockets are end of life.
It's not like he doesn't have an upward path with AMD even if the platform is eol. Getting a DDR4 intel board will mean you'll probably want to upgrade that anyways later so not really much of a distinction.
https://linustechtips.com/topic/1440655-first-pc/#findComment-15463115
Sure, but at least on intels side you'll get the new innovations on intels 13th gen while on the other hand ryzen final release was the 5800x3d iirc. Im not saying am4 dosent have any upgradibilty, it just won't be as good as raptor lake appears to be. My point still stands though that the 4500 will definitely get outclassed by the 12400f
https://linustechtips.com/topic/1440655-first-pc/#findComment-15463135
While I agree the 12400f would cream the 4500 it's not exactly a good choice on his end cause it's 100 bucks less with the cpu/mobo combo lol. Not saying he shouldn't go intel but personally I really enjoy how low power my ryzen desktop is even at full load in the summer heat.
https://linustechtips.com/topic/1440655-first-pc/#findComment-15463140
Yea, that about what id expect from a worse perfroming chip. I'm fairly confident I've stayed within budget.
Although the mobo i suggested appears to have gone off sale.
If they would want to constrain further to the budget,  the cpu cooler could be removed, 16 gigs  of ram, cheaper case ect. Sure you could get a worse cpu pump it all into the gpu or save it, but I'd rather make a balanced list within the budget that was given
I'd pay 70 dollars extra for a 12400f and b660 imo, but op can do what they want
https://linustechtips.com/topic/1440655-first-pc/#findComment-15463172
My recommendation...
PCPartPicker Part List
CPU: Intel Core i5-12400F 2.5 GHz 6-Core Processor  ($169.95 @ Amazon)
Motherboard: Gigabyte B660M DS3H DDR4 Micro ATX LGA1700 Motherboard  ($109.99 @ Amazon)
Memory: Silicon Power GAMING 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($46.97 @ Amazon)
Storage: ADATA XPG SX8100 1 TB M.2-2280 NVME Solid State Drive  ($89.99 @ Amazon)
Video Card: Gigabyte Radeon RX 6700 XT 12 GB EAGLE Video Card  ($459.98 @ Newegg)
Case: Cougar MX330-G ATX Mid Tower Case  ($56.99 @ Amazon)
Power Supply: Phanteks AMP 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($69.99 @ Newegg)
Total: $1003.86
Generated by PCPartPicker 2022-07-02 03:15 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1440655-first-pc/#findComment-15463243
The R5 4500 is total crap though. The R5 5500 already gets beaten by the i3 12100/F.
https://linustechtips.com/topic/1440655-first-pc/#findComment-15463532
Total: $1003.86
Why are you recommending one of the worst, and most basic, motherboards you can get with b660? It's not like OP's budget is that tight. Going with Ryzen would surely allow for a better motherboard, with better vrms, and an integrated I/O shield.
https://linustechtips.com/topic/1440655-first-pc/#findComment-15464261
Performance will speak for itself.
12400f  + 6700xt >>>> 5600 + 6600xt
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1440655-first-pc/#findComment-15464298
They might as well buy a prebuilt, with that crappy motherboard.
https://linustechtips.com/topic/1440655-first-pc/#findComment-15464352
