Help
Solved by dj_ripcord,
Unused memory is wasted memory, Windows will use free memory to cache things for performance reasons.
Explain a little further: this has nothing to do with your PSU upgrade. More likely the reboot made Windows do a re-evaluation of it's hardware use and used some RAM for cache since it found you don't use all 32G very often.
3
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases5 -
2
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning18
play_circle_filled
Latest From ShortCircuit:
