So I was thinking of buying a new PC this month and I would need some help. For a start I'd like to but a decent mobo and myb a cpu with it, which combo would work good? I found this mobo GIGABYTE H510M H (rev. 1.0) Maticna Ploca (149 KM)
https://www.olx.ba/r/46272341/1769792 its intel tho I prefer AMD sockets but idk. Looking for some budget parts nothing overpriced pls something rly cheap
https://linustechtips.com/topic/1438894-pc-parts-help/
7 minutes ago, Caroline said:
Hi.
The catch with Intel platforms is that you can often find cheap mobos but then the CPU is worth a kidney, or -if you go for an entry level CPU- you end up with a dead platform with no chance to upgrade any further unless you go used.
I guess 149KM is the price, I don't know the language but also found this.
https://www.olx.ba/artikal/46323157/asus-maticna-ploca-mbo-am4-as-prime-b450m-k-ii/
thats a good mobo right?
https://linustechtips.com/topic/1438894-pc-parts-help/#findComment-15450519
If someone ask me for an advice in building a new pc, I normally have 3 questions. What's the specs of your current pc? how much is your budget? What will you run with it(games/apps)? From there, we would know if its worth it to build a new system or just upgrade the current one.
https://linustechtips.com/topic/1438894-pc-parts-help/#findComment-15450584
my current, FX 6300, Gigabyte GA 78lmt s2, GTX 770 2GB which died 2 days ago, RAM 8GB HyperX fury. My budget is like not a lot. Id like the parts that are rly cheap like the cheapest ones but that are still good u know? the cheapest good ones. So any suggestion would help a lot. I don't have a number yet like how much money but yea
https://linustechtips.com/topic/1438894-pc-parts-help/#findComment-15451061
