Advice for first PC build?
Unless you're crazy overclocking, AIO is overkill for a 5600X. The X doesn't gain much on PBO anyway, and the 5600 is cheaper. 5600X will stay within limits with a stock Wraith cooler without crazy overclocking, though I'd recommend a tower air cooler. If you're really stuck on AIO, though, (I don't recommend them as they create unnecessary extra hassles in troubleshooting), you might consider a 5800X, which actually needs it and performs better.
Also, from a bang-for-the-buck standpoint, the cost of the AIO and 5600X gets you most of the way to a 5800X ($309). A Scythe Mugen S is under $60, and a few case fans aren't much more. If you really want white all over, a light coat of white spray paint on the Mugen S would have you covered, there's also the Noctua NH-D15 with white heat sink covers, albeit more pricey. The 5800X gives lots better performance potential and future-proofing than the 5600X too. I air-cool a 5900X with a Scythe Mugen 5, so if that cools in my 4000X case, I know that will work in your Lian Li.
However, Ryzens don't seem to like Corsair RAM, I would recommend Crucial Ballistix RGB DDR4-3200 in white, and add a slight OC if you like, to get it to around 3600. You'll be much better off, believe me.
