If it can be mass produced and is economically viable for them to do so, sure. Wouldn't be the first time a "it works in the lab" technology takes decades to come to market, though.
https://linustechtips.com/topic/1438619-light-cpu/#findComment-15448521
Do u think it would revolutionize 4k or even 8k gaming?
https://linustechtips.com/topic/1438619-light-cpu/#findComment-15450156
No. The higher the resolution, the less work the CPU has to do, relative to the GPU. So if anything, you'd need a light GPU. But as I said above, I expect this technology to take decades to actually come to market. Who knows what resolutions will be current by then.
https://linustechtips.com/topic/1438619-light-cpu/#findComment-15450599
im sure they will implement it to the gpu as well, dont the cpu and gpu kinda work the same excluding what they do?
https://linustechtips.com/topic/1438619-light-cpu/#findComment-15454512
