pci-e PCI Express Lane Allocation Issues
7 hours ago, Needfuldoer said:If all you need is bulk storage, and you haven't filled all your SATA ports yet, an additional SATA SSD will be fine.
Here's what your motherboard's manual has to say about slots sharing bandwidth:
(Page 6 of the PDF)
(Page 10 of the PDF)
So if I'm reading this right:
M.2_1 gets 4 dedicated lanes no matter what.
If you populate PCIEX16_1 and PCIEX16_2, they'll each get 8 lanes. PCIEX16_1 gets all 16 lanes if PCIEX16_2 is empty.
If you put anything into either PCIEX1_1 or PCIEX1_2, PCIEX16_3 will only run at 2 lanes instead of 4 (which is electrically a 4x slot at most). These all hang off the chipset's dedicated 4 lanes.
If you populate M.2_2, you lose SATA ports 5 and 6.
Do you have anything in PCIEX16_2?
I think if you install a riser into PCIEX16_2, you could add two M.2 SSDs that would each get their own 4 lanes, but don't quote me on that.
First of all thank you for taking the time and interest to assist me with this conundrum.
The reason for the addition is not bulk storage, but to move the old Samsung drive into my wife's laptop because it has NO bulk storage at all. Semi related note, I've just re-seated my GPU's power cables and now GPU-Z is reporting its running at 16 speed so yay there.
As for the question RE: additional PCIe devices, there are none but since I've solved the primary bifurcation issue by just re-seating the power, if I stick the SN770 on the PCIe card into slot PCIEX 6_3, I should at least get that to run at full PCIe Gen3 x4 which is fast enough for my minuscule needs without impacting the GPU.
