Hey
i just got my Noctuna NF-F12 Fans 120mm 12v
that i will use in Push pull config.on my CPU with a Hyper EVO 212 Evo Radiator.
Atm i running the Pull Fan on the CPU_fan header_OPT
and i saw there was a Y-split cable whit the fans,
Is it safe to put that split on CPU_FAN_HEADER
to maintain the same speed on both of the fans?
the mobos fan header is supporting 12v so 2 fans whit a Y-split will it double the voltage and burn the Header ?
thx
Posted a img from my Manual for my motherboard ASUS-X99A
https://linustechtips.com/topic/1436952-y-split-cable-from-cpu-fan-header/
Yes, you can use a Y-splitter on that header. Most fan headers are rated for at least 1A, some more.
NF-F12 is very power efficient.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
unless your other fan is some 2A delta blowiematron, it's just fine to use the splitter. that said, on most motherboards with a cpu_opt header it basicly already is an on-board splitter.
Okay Nice 😄 do you think there will be a noticeable temp difference running a Y-split instead of have the fans connected to CPU_fan_OPT And CPU_fan_Header
they are both NF-F12's 🙂
There is no difference. In most cases the CPU_OPT header is just slaved to the CPU_FAN header anyway, it really won't matter.
Okay! then i just go whit the setup i have right now!
i did notice 1 + - 2c temp difference when i changed the Push fan connector from CPU_Header_OPT to CPU_Header
i just connect the Y.splitter!, so when i control the speed for the CPU both fans will show up as one vice versa?
