Hi!
I'm running a Ryzen setup on an A320M mobo (to be specific, a Gigabyte A320M-S2H with 2 DIMM slots). Normally, I run 12GB of RAM with a 4GB stick (lets call this one stick A) and a 8GB stick.
So a while ago, I was just playing a game on my PC with no issues until the PC froze. I decided to hit the reset button, but then my PC wouldn't even hit the post screen. I tried to swap the arrangement of my two ram sticks and also tried to boot the PC with just one of each at a time on both slots to no avail. I then pulled out a single spare 4GB stick I had (lets call this one stick B because it's identical to the 4GB stick I ran normally), and on its own, the PC booted normally into Windows. I then tried it with Stick A, then it ended up booting normally as well. But when I tried it with my 8GB stick, it booted normally but Windows and my BIOS reported the 8GB stick as a 4GB only, so instead of having 12GB as I normally would, I only had 8.
Now the issue gets even stranger here.
I swapped out the 8GB stick again for Stick A, but unlike the first time I combo'd Stick B with Stick A, the PC wouldn't post at all. So then I switched it back to the Stick B + 8GB configuration, but for some odd reason, this configuration only works if Stick B is on the left and the 8GB stick is on the right. If I were to swap their positions, the PC would not post. But for some reason, the PC would happily boot normally with Stick B regardless of which DIMM slot I throw stick B in.
So my main question is this: Is it the motherboard's DIMM slots that are damaged? Or is it the original pair of RAM sticks that I ran with?
Just to repeat:
Stick A = My original 4GB RAM stick
Stick B = A spare 4GB RAM stick that is identical to Stick A.
EDIT :
So I just decided to throw in the original 2 RAM sticks together, and it somehow booted normally with the 8GB stick reporting as it is, so now I'm back to 12GB of RAM. My question still stays the same though.
Edited by swftre
https://linustechtips.com/topic/1436846-confusing-ram-issue/
