Greetings,
I have recently run into a problem and would request help fixing it.
I have an Dell Inspiron laptop on which I wanted to install an Solid State Drive to make it faster, I installed an 128GB SSD and used a Hard Drive Caddy to install my existing 1TB Hard Drive as well.
For back up of my data I made a windows image from the Windows 10 settings.
I have installed Windows on my SSD and want to recover the above mentioned data. For this purpose I made a bootable USB drive and went ahead and clicked on Repair My Computer when prompted, on the recovery screen I selected the WIndows Image Recovery option. My image shows there but it shows some error.
The windows image is in the .vhdx format.
I wish to recover 2 folder inside the windows users namely pictures and 3d objects.
Not really sure how to proceed.
Need your help.
Thanking you.
https://linustechtips.com/topic/1436734-help-with-vhdx-image/
So you reinstalled windows and you only want those folders?
Then in your new windows install right click the vhdx file to mount it as a drive and copy the data over.
https://linustechtips.com/topic/1436734-help-with-vhdx-image/#findComment-15435566
23 minutes ago, duncannah said:
You can mount VHDX files on Windows:
I cant seem to open up the WindowsImageBackup on the same laptop.
I actually copied the files (Windows10Upgrade and WindowsImageBackup) to another laptop(say laptopB) running windows 7 and cant actually find the mount option on LaptopB.
And on my original laptop(say laptopA) i cant open the WindowsImageBackup folder.
https://linustechtips.com/topic/1436734-help-with-vhdx-image/#findComment-15435576
4 minutes ago, C2dan88 said:
Try disk management (file > attach vhd)
Thank you for replying,
I did that but at first it shows that the media is write protected.
Then I checked the read-only box, and was able to attach the file but i cannot see any option to open it in the disk management window neither in My Pc as a separate drive
https://linustechtips.com/topic/1436734-help-with-vhdx-image/#findComment-15435608
