PC Audio (ALC4080 + Savitech SV3H712 AMP)
12 minutes ago, cmndr said:CD Quality is 16bit 44.1KHz. Which is plenty for most use cases (though you can lose some fidelity if you shift volume settings, change the EQ, have dynamic range compression, etc.)
It doesn't matter a ton. Probably doesn't hurt to do 24 bit which mostly obviates any quality reduction from shifting multiple volume settings.
44KHz vs 192KHz is highly unlikely to matter in practice since a 44KHz sampling rate will get you perfect replication above 20KHz (which is probably higher than you can hear anyway) I've heard some arguments that going to 48KHz might help with the upper rolloff since often low-pass filters are applied to audio but... I haven't seen much evidence other than a random on the internet.
Thanks. I'll try playing with the bass and treble volumes first while switching from 16 - 32 bit up to 48kHz quality. So far I'm liking the 32 bit 44100 Hz Studio Quality - on how it sounds on my ATP3 2.1 speakers. The twin downfires gets a better feedback with this setting so far.
