43 minutes ago, mcloude said:
Looking into buying a new Battery back up (UPS) at least 900watts minimum. Looking for 1 that doesnt catch fire. was looking at APC BR1500MS2,  APC BGM1500B and CyberPower CP1500AVRLCD. i just read to many horror reviews and unsure. Any help would be appreciated thank you
Didn’t LTT just do a video on something that would cover that?  Made by Anker iirc.
Edited by Bombastinator
https://linustechtips.com/topic/1436630-battery-back-up-ups/#findComment-15434802
The Anker device is more of a portable power station of camping and such, rather than a UPS.
I have the APC BR1500MS2, seems to work great though I haven't actually had to rely on it in a power outage yet. The CyberPower one is almost identical in spec so you're probably good with either. I wouldn't bother with the APC "gamer" UPS, it's pretty much the same performance for 25% more money. All you get is a slightly fancier display and the option to get it in white. My workplace also uses tons of APC UPSes, which haven't burned the place down so far. Both manufacturers have a warranty that covers equipment damaged while protected by the UPS as well, though how supportive they are if you actually try to claim it is something I haven't investigated.
Main rig:
CPU: AMD Ryzen 9 5900X
GPU: Sapphire RX 6800XT
RAM: 2x16GB DDR4
Motherboard: Asus ROG B550-I
Storage: 2TB Samsung 980 PRO NVMe, 4TB WD Blue HDD
PSU: Corsair RM850x
Case: Fractal Torrent Nano
OS: Linux Mint 20.2 Cinnamon
NAS:
CPU: AMD Ryzen 4600G
Motherboard: ASRock Rack X470D4U
RAM: 2x16GB DDR4
Storage:
  • Boot: 16GB Supermicro SATADOM
  • Pool 1: 2x6TB WD Red Plus HDD mirrored, for bulk storage
  • Pool 2: 2x500GB NVMe SSD mirrored, for apps like Plex and Adguard Home
PSU: Be Quiet SFX-L 600W
Case: Silverstone CS351
OS: TrueNAS SCALE
https://linustechtips.com/topic/1436630-battery-back-up-ups/#findComment-15437293
I doubt many of them catch fire.  Perhaps you’re looking for lead acid batteries then?  I don’t know why they’re not used more often anymore really UPSes for desktops often simply don’t care about how physically large things are.  Shipping weight possible.   lead is so heavy it’s like it made of lead.
https://linustechtips.com/topic/1436630-battery-back-up-ups/#findComment-15437326
It’s also LiIon.  There are battery backups and UPSes. Some battery backups can be used as UPSes if they can be charge while they are being drawn from.  I guess the post was a rather unclear imprecise request for clarity.
https://linustechtips.com/topic/1436630-battery-back-up-ups/#findComment-15437331
Yeah. Li-Ion is good for capacity, but they are prone to going up in flames. That and they wear out quickly if left at maximum charge, which is where a UPS will spend the overwhelming majority of its life. That's why true UPSes use older lead acid technology.
Main rig:
RAM: 2x16GB DDR4
PSU: Corsair RM850x
NAS:
RAM: 2x16GB DDR4
Storage:
OS: TrueNAS SCALE
https://linustechtips.com/topic/1436630-battery-back-up-ups/#findComment-15437347
They can if you screw up.  Screwing up includes buying counterfeit or low quality batteries.  Also they need to be recycled before they go bad.  Basically anything with sufficient energy density is prone to explosion though.  Grain dust will explode. Used to be a real problem.  Lead acid batteries will explode if there are no safety measures.  That used to be a problem too. The only way to truly avoid that is low energy density which means a gigantic battery.
https://linustechtips.com/topic/1436630-battery-back-up-ups/#findComment-15437657
