What would be the best setup for having a mesh wifi system for a very large property, property size is 1.88acres. There aren't any wires connecting any of the buildings and it's roughly 35-40m distance between the two buildings. All building have metal siding. I would like to setup IP cameras in the other buildings.
https://linustechtips.com/topic/1435815-mesh-wifi/
Is this a personal property or a workplace?
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/1435815-mesh-wifi/#findComment-15428533
2 hours ago, TURBO420sx said:
Personal property, it's a farm property.
Some outdoor point to point link would make sense, as standard WiFi is not as reliable outdoors as protocols customised for outdoor use.
https://linustechtips.com/topic/1435815-mesh-wifi/#findComment-15430246
4 hours ago, TURBO420sx said:
Thanks for the reply, I'll take a look at some outdoor point to point links
Bear in mind you'd then need a WiFi Access Point for the inside of the building (or a switch), but given the metal siding that's pretty much a given no matter what.
https://linustechtips.com/topic/1435815-mesh-wifi/#findComment-15430556
