Don;t spend $200 on a 1050ti.  You can get a 1070 on eBay for $200, or a 6600 new for $300.
You could get the 6600 if you skip the windows key.  Digital windows keys can be bought on ebay for $5.
I edit the shit out of my posts.  Refresh before you respond.
https://linustechtips.com/topic/1435040-first-pc-build-input/#findComment-15422888
I just realized you wanted a disk drive. While I recommend against it, this parts list will be better for that, as the case has better airflow than the corsair one, comes with fans, and has mounting bays for an optical drive.
PCPartPicker Part List
CPU: Intel Core i5-12400F 2.5 GHz 6-Core Processor  ($159.98 @ Newegg)
Motherboard: MSI PRO B660M-A WIFI DDR4 Micro ATX LGA1700 Motherboard  ($139.99 @ GameStop)
Memory: Silicon Power XPOWER Turbine 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($49.97 @ Amazon)
Storage: Silicon Power A60 1 TB M.2-2280 NVME Solid State Drive  ($73.98 @ Amazon)
Video Card: XFX Radeon RX 6600 8 GB Speedster SWFT 210 Video Card  ($299.95 @ B&H)
Case: Fractal Design Focus G Mini MicroATX Mini Tower Case  ($64.99 @ B&H)
Power Supply: Corsair CV 650 W 80+ Bronze Certified ATX Power Supply  ($41.99 @ GameStop)
Total: $830.85
Generated by PCPartPicker 2022-06-03 14:31 EDT-0400
$830 with a better motherboard, onboard wifi, much faster video card (RX 6600) and a 1TB SSD instead of 500GB.  The corsair CV is not quite as good as the CXM, but with a 12400f and a 6600 it doesn't really matter.  It's a 300w system on a decent 650 w PSU.  As long as it's not total crap it fine.
Don't buy a new optical drive, every thrift store, surplus sale and dumpster has at least 3 in it just laying around.  Your mom probably has one in her basement.
https://linustechtips.com/topic/1435040-first-pc-build-input/#findComment-15422904
