Wall mounting Samsung S95B question
lostboykev
The mounting holes are a different depths as you can see from my attached picture. Has anyone encountered this? Do I just use a universal mount with very long bolts? Or if someone can recommend me a good stand on Amazon or pick up from Best buy I'll order it.
Samsung TVs usually come with plastic spacers which fit into those holes and level the VESA holes out, then you're meant to use extra-long bolts to reach the threads.
Stack up some fender washers between the mount and the chassis to make up the space. You're just keeping the display from wobbling.
Thanks for the tip and I'll check for the spacers. Only had my lunch time to get it out of the box.
