OS Help! For new build
Solved by JLCitadel,
sorry i should have asked differently... im leaning towards windows but not sure what version is best for gaming
If you like 8.1 use it. If you don't then use windows 7. People who don't use 8.1 dislike it. Not don't use it cause 7 is better or 8.1 is better. They're the same. Eventually 8.1 will be better, so if you are willing to use it and like it then get used to it now.
