Well, what is not doing.  Is this a pic of your final build because it is missing a lot of connections that still have to be done.  If this is a pic of the final build, then you need a cooling solution, memory is not seated properly, front panel connections are missing........etc.
https://linustechtips.com/topic/1434192-i-need-help/#findComment-15416686
