I've got a Cat6a SOHO setup where I've individually tested:
-All cables used (with cable tester):
- - Cable from PC to wall outlet
- - Cable from wall outlet to patch panel
- - Cable from patch panel to switch
- Running long cable from switch to PC (with a Cat5e cable)
And yet when I connect my PC to the wall outlet it will temporarily say "identifying" and then disconnect again.
So as far as I can see it seems like it "knows" it's there, but either something crashes or something is maybe configured wrong?
Though I can't imagine what considering it seems fine when connecting Cat5e directly to the switch.
Any ideas?
EDIT:
Nvm sorted it out, I had twisted the actual plate to visually sit the way I wanted.
This caused the cables to get twisted which presumably caused interference.
The wallplate looks upside down now but it works 😂
https://linustechtips.com/topic/1434014-cat6a-problems-soho/
