How to set "LCD Custom string"?
Go to solution Solved by Kilrah,
These seem to all be hardcoded things that can only be enabled/disabled, seems there is one called "Custom string" but it'd be for the manufacturer to customize and you as user can only choose to display it or not.
I have a Celsiue M470 which has a lcd built in, and connected to the motherboard's internal lcd connector. I recently noticed that there is an option to set a custom string in the bios, and I saw another forum that asked this, but it never got an answear, there is also said that my pc, should support custom strings.
Is there a way to change a the "Custom string" on the lcd?
I couldn't find any submenus to set it. There is only an option to Enable or Disable it.
Mentioned forum: https://forum.ts.fujitsu.com/forum/viewtopic.php?t=43870
Motherboard PDF: https://data2.manualslib.com/pdf4/89/8890/888922-fujitsu/d2778.pdf?2baf7e24425bb78da6136724d1ab6541
https://linustechtips.com/topic/1432858-how-to-set-lcd-custom-string/
There is a certain amount of “why” attached to this one.  I’m not sure kicking a label maker fetish is worth it.
What's the question? You said you found a BIOS option to set it, so... set it and see if it works?
F@H
GPD Win 2
10 minutes ago, EEE SPROTS said:
Title: How to set "LCD Custom string"?
You said:
So set it?
F@H
GPD Win 2
We're trying to understand what you're saying because in one post you initially said there is a BIOS option for it, and now in another post you say there's no BIOS option for it.
If there isn't one then you likely can't change it.
F@H
GPD Win 2
There is an option to "Enable" and "Disable" it, but I could not find a way to *set* it.
If there has to be a way to set it otherwise you probobly would not be able to Enable or Disable it. But I'll send pictures.
1 hour ago, EEE SPROTS said:
It would be cool, I think, thats why
Fair enough.
F@H
GPD Win 2
