Budget (including currency): £3000 (room for slightly overbudget)
Country: Uk
Games, programs or workloads that it will be used for: Playing games and vr. Blender is optional but would be nice
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): https://uk.pcpartpicker.com/list/xsPcxs
I would like opinions on this build and opinions. If anything needs changing I would appreciate small changes as opposed to a whole new build
https://linustechtips.com/topic/1432375-adjusted-first-build/
why dont you just continue the other threads instead of making 3 threads in 1 day?
https://linustechtips.com/topic/1432375-adjusted-first-build/#findComment-15404759
An i7-12700K outperforms a 5900X in most titles and in Blender.
The motherboard does not provide native support for the case front panel USB-C port.
1000W PSU seems a bit excessive.
https://linustechtips.com/topic/1432375-adjusted-first-build/#findComment-15404763
Quote
Ohhh thank you for the suggestions
Besdies changing the cpu and the motherboard would everything else still be the same?
And the motherboard is my main problem when part picking so do you have any recommendations?
https://linustechtips.com/topic/1432375-adjusted-first-build/#findComment-15404773
Up to you if you want to go with an 850W PSU. Otherwise, while I'm not a fan of some of the choices, they are decent quality and will provide the desired results.
PCPartPicker Part List
CPU: Intel Core i7-12700K 3.6 GHz 12-Core Processor  (£351.80 @ Amazon UK)
CPU Cooler: NZXT Kraken X53 73.11 CFM Liquid CPU Cooler  (£114.63 @ CCL Computers)
Motherboard: MSI MAG Z690 TOMAHAWK WIFI DDR4 ATX LGA1700 Motherboard  (£235.98 @ Novatech)
Memory: Crucial Ballistix 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory  (£168.83 @ Amazon UK)
Storage: Western Digital Black SN850 2 TB M.2-2280 NVME Solid State Drive  (£231.30 @ Amazon UK)
Video Card: MSI GeForce RTX 3080 12GB LHR 12 GB GAMING Z TRIO Video Card  (£969.59 @ Newegg UK)
Case: Corsair iCUE 4000X RGB ATX Mid Tower Case  (£99.98 @ AWD-IT)
Power Supply: Corsair RMx (2021) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (£139.99 @ AWD-IT)
Operating System: Microsoft Windows 11 Home OEM 64-bit  (£88.90 @ Alza)
Monitor: Alienware AW2721D 27.0" 2560x1440 240 Hz Monitor  (£697.03 @ Amazon UK)
Total: £3098.03
Generated by PCPartPicker 2022-05-21 04:14 BST+0100
https://linustechtips.com/topic/1432375-adjusted-first-build/#findComment-15404778
