Building my first PC (Aerospace Engineer)
Solved by brob,
I'm not a fan of the case because of its acrylic window. But I understand the selection, there are not many options these days for cases with 5.25 external drive openings.
Consider going with an i7-12700F rather than the i7-12700K. The saving is substantial. The stock performance differential is small. About 6% for a Chromium compile, depending on cooling and power settings.
12th gen Intel CPU performance depends on cooler efficiency. I'd suggest something like the Dark Rock Pro 4. Interestingly, locked 12th gen have max power quite close to their unlocked counterpart.
I would chose a 550W modular PSU, despite the added cost.
