Arctis Pro Wireless audio cutting out. Please HELP
Solved by B1GLeo,
Do you see 2 sound inputs in Windows (Game and Chat one) when this happens? I would first of all disable fast boot (that used to cause many issues with mine), so that only fix was to unplug the cable from PC and plug it back in to get both sound outputs working.
I didn't have Wireless version but I believe if this does not help it would be faulty headset or an electrical interference like you mention.
I would definitely try going with their support and see what they say - https://support.steelseries.com/hc/en-us
