Need help overclocking
Go to solution Solved by Shimejii,
Most ryzen chips you pretty much cant OC very much, besides PBO and voltage tuning, there is not much you can do to the CPU itself. 2600x was pretty much limited to 4.0 ghz, rarely able to do a all core to 4.1 to 4.2.
https://linustechtips.com/topic/1431172-need-help-overclocking/#findComment-15396408
In the BIOS, you'd go to the AI tuner or AI overclock menu (whatever it is named on this particular board) and you'd change the clock speed settings and voltage in there.
As @Shimejii mentioned, if PBO is enabled the CPU is probably near its fullest potential. Although, I've noticed the setting is often rather buried in some esoteric menus.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1431172-need-help-overclocking/#findComment-15396424
