There is an option in ´Settings´ that lets you unlock the voltage control. You need to check the box that says ´Unlock voltage control´. Not all cards support this though, so you might not be able to do it.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/143110-overclocking-help/#findComment-1910500
You cannot voltage control 7770's AFAIK, i managed 1200mhz on stock XFX voltages, 1.2v i think.
Le Bastardo+
i7 4770k + OCUK Fathom HW labs Black Ice 240 rad + Mayhem's Gigachew orange + 16GB Avexir Core Orange 2133 + Gigachew GA-Z87X-OC + 2x Gigachew WF 780Ti SLi + SoundBlaster Z + 1TB Crucial M550 + 2TB Seagate Barracude 7200rpm + LG BDR/DVDR + Superflower Leadex 1KW Platinum + NZXT Switch 810 Gun Metal + Dell U2713H + Logitech G602 + Ducky DK-9008 Shine 3 MX Brown
Red Alert
FX 8320 AMD = Noctua NHU12P = 8GB Avexir Blitz 2000 = ASUS M5A99X EVO R2.0 = Sapphire Radeon R9 290 TRI-X = 1TB Hitachi Deskstar & 500GB Hitachi Deskstar = Samsung DVDR/CDR = SuperFlower Golden Green HX 550W 80 Plus Gold = Xigmatek Utguard = AOC 22" LED 1920x1080 = Logitech G110 = SteelSeries Sensei RAW
https://linustechtips.com/topic/143110-overclocking-help/#findComment-1910503
Thanks, is another program that will let me unlock it.
Also I have ticked the box and also tried putting it in unofficial overclocking mode
As @Recon-UK said, the card is voltage locked. This means that it's probably either a hardware or a BIOS lock, and you don't want to be messing with that.
You can try EVGA Precision X, but I doubt that it will do anything different.
https://linustechtips.com/topic/143110-overclocking-help/#findComment-1910522
Better off not touching bioses unless you are 110% sure and ready to take responsibility if you brick your card.
Le Bastardo+
Red Alert
https://linustechtips.com/topic/143110-overclocking-help/#findComment-1910548
if I did change the bios would it be reversible or not?
If flashed correctly both times, yes.
Le Bastardo+
Red Alert
https://linustechtips.com/topic/143110-overclocking-help/#findComment-1910590
It is reversible, aslong as you have a back-up of the original BIOS file.
However of the BIOS file is in any way edited wrong, it can lead to the card getting bricked. And if the card is bricked, the warranty won't cover.
And there is still the possiblility of it being a hardware lock, which means that a BIOS unlock won't help.
https://linustechtips.com/topic/143110-overclocking-help/#findComment-1910591
what are the chances of it getting bricked?
50/50.
I personally have never bricked a card, but i am not a casual user.
Le Bastardo+
Red Alert
https://linustechtips.com/topic/143110-overclocking-help/#findComment-1910608
i guess once it is bricked there is no way back
There is, but you need another GPU, however you have a chance that you still cannot save your card, bad flashes are not all the same.
Le Bastardo+
Red Alert
https://linustechtips.com/topic/143110-overclocking-help/#findComment-1910622
To see the screen, Windows will not see the bricked card, thus no display.
Le Bastardo+
Red Alert
https://linustechtips.com/topic/143110-overclocking-help/#findComment-1910664
that doesn't sound good so i guess i wont try with the bios stuff cuase i dont want a bricked card
thanks for your help
No problem :)
Le Bastardo+
Red Alert
https://linustechtips.com/topic/143110-overclocking-help/#findComment-1910680
