i am in the early planning off my custom loop and i was thinking of getting 2x 360 mm rads for my o11d xl and the distro plate with included pump and put it in the side slot because it woud probably be easier and look a bit cool and i am asking if this is a good idea i mean if the pump is strong and such things i have a r7 5800x and a 3080 ti and i would go for hard tubes if you have any tips or advice feel free to comment
https://linustechtips.com/topic/1430224-pump-or-combo/
No need for a combo if buying a plate. Any quality pump d5 or ddc is gonna be fine for that system.
https://linustechtips.com/topic/1430224-pump-or-combo/#findComment-15392190
Built in this case with 2x360mm and 1x240mm a few years back, single D5 did fine cooling 9900x and a pair of 2080tis.
Screwdriver specs: Long, pointy. Turns things. Some kind of metal.
Main rig:
i9-7900x | Asus X299-Prime | 4x8GB G-Skill TridentZ @3300MHz | Samsung 970 Evo 500GB | Intel 5400S 1TB | Corsair HX1200
unRAID server:
Xeon  E5-1630v4 |  Asus X99-E WS | 4x8GB G-Skill DDR4 @2400MHz | Samsung 960 EVO 250GB cache drive | 12TB spinning rust | Corsair RM750X
FreeNAS server:
AMD something-or-other | Asus prebuilt sadness | 8GB DDR3-1600 | 9TB magnetic storage | Potential fire threat
HTPC:
i7-4790 | GTX1650 | Dell Sadness | 12GB DDR3-1600 | Samsung 860 250GB | 1TB magnetic storage | James Loudspeaker SPL3 x2 | Corsair SF450
https://linustechtips.com/topic/1430224-pump-or-combo/#findComment-15392308
