I have a uhm... troubleshooting problem with my pc. I create several topics asking for help!
Build my first pc. Comments:
Cpu: ryzen 5600x
Motherboard: msi b550 a pro
Gpu: msi 3070 ti supreme x
Ram: g.skill ripjaws dual 16gb
Storage: nvme inland 2t, high read and wrights speeds 4000-5000
Psu: antec hcg 650w 80+ gold
Case: p400a
 I dont know why its not working. There is no power no lights when i click case power button. I made sure every thing is plug in. Then I even updated my motherboard bios to the latest version, named it  MSI.ROM to the file, formatted to fat32, red light flashing and their was a white light to the right, gave a few minutes and the white light remained, thought it was done and unplug the usb. With everything plug in, 24 pin, cpu 8 pin, 2 pcie 8 pin, and the tiny power pins in, hit the power button, still no power what so ever.
 I check if psu if it works even though it was able to power the motherboard for bios update, i checked the psu, by pluging in a paper clip into the 24 pin where it should go and the the fans did spin on the psu. Now i don't know why nothing wants to power on.
 I am sure that i plug in the 24 pin, cpu 8 pin, 2 pcie pin into the gpu, and the case pins for power, even the fans in all correct, yet still nothing powers on. No fans spins, no lights, nothing.
I am extremely upset at the problem i yet to understand, please help!
https://linustechtips.com/topic/1430114-computer-does-not-power-up-nothing/
If this is the case, what lights did you see when you supposedly attempted updating your BIOS? These 2 scenarios don't coincide.
Edit: don't make multiple post for the same issue.
Primary Gaming Rig:
Ryzen 5 5600 CPU, Gigabyte B450 I AORUS PRO WIFI mITX motherboard, PNY XLR8 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 500GB SSD (boot), Corsair Force 3 480GB SSD (games), XFX RX 5700 8GB GPU, Fractal Design Node 202 HTPC Case, Corsair SF 450 W 80+ Gold SFX PSU, Windows 11 Pro, Dell S2719DGF 27.0" 2560x1440 155 Hz Monitor, Corsair K68 RGB Wired Gaming Keyboard (MX Brown), Logitech G900 CHAOS SPECTRUM Wireless Mouse, Logitech G533 Headset
HTPC/Gaming Rig:
Ryzen 7 3700X CPU, ASRock B450M Pro4 mATX Motherboard, ADATA XPG GAMMIX D20 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 1TB SSD (boot), 2x Seagate BarraCuda 1 TB 3.5" HDD (data), Seagate BarraCuda 4 TB 3.5" HDD (DVR), PowerColor RX VEGA 56 8GB GPU, Fractal Design Node 804 mATX Case, Cooler Master MasterWatt 550 W 80+ Bronze Semi-modular ATX PSU, Silverstone SST-SOB02 Blu-Ray Writer, Windows 11 Pro, Logitech K400 Plus Keyboard, Corsair K63 Lapboard Combo (MX Red w/Blue LED), Logitech G603 Wireless Mouse, Kingston HyperX Cloud Stinger Headset, HAUPPAUGE WinTV-quadHD TV Tuner, Samsung 65RU9000 TV
if you are sure it's not turning on with the power switch, try shorting the power pins with a screwdriver to rule out a faulty pwr switch. i would also try updating the bios again, and make sure every step is correct. if those don't work, i would probably try an rma on the motherboard. not a concrete guess, but my best guess if you have no other way to narrow it down(spare pc to test the components in).
Red flashing light by the bios button and to the opposite side of the motherboard a soild white light. Step away for a bit came back to fine the red light had stop flashing amd only the white light remain. Thats when i took out the usb and build my computer back connected everuthing with the same problem, possibly the same problem. Im going to rebuild my computer a 3rd time and update latest bios again for the 2nd time
