Hello,
I was looking to buy a pre-built pc from lenovo and wanted to ask some questions about the psu, mb etc.
The pc i was looking to buy is this
https://www.lenovo.com/lv/lv/desktops-and-all-in-ones/ideacentre/500-series/IdeaCentre-5-Gaming-Gen-6-AMD/p/WMD00000495?orgRef=https%3A%2F%2Fwww.google.lv%2F
The most concern i have is about this psu called AcBel pcj007. Never heard about it, and it looks like office type psu. Im not sure that it would be able to handle this build
ryzen5 5600g
rtx 3060 12gb
16ram
Thank you
https://linustechtips.com/topic/1430010-pc-and-psu-help/
Although weak, those aren't bad (true 80+ Platinum). But they use proprietary connections and probably a non-standard size, so you'd have issues upgrading or replacing.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1430010-pc-and-psu-help/#findComment-15388437
4 minutes ago, eldzys said:
Can it run that type of build without problems?
With 310W I would not.
https://linustechtips.com/topic/1430010-pc-and-psu-help/#findComment-15388445
