Drivers help
Go to solution Solved by Middcore,
Just now, Wolly9102 said:
All drivers are downloaded automatically by Windows. No user download is needed.
Well, this isn't quite true.
Once the system is built, OP should download and install the latest drivers for their GPU from Nvidia: https://www.nvidia.com/en-us/geforce/drivers/
And they'll probably also want the AMD chipset drivers, onboard audio drivers, and LAN drivers for their motherboard from MSI: https://www.msi.com/Motherboard/MAG-B550-TOMAHAWK/support#driver
Budget (including currency):
Country:
Games, programs or workloads that it will be used for:
Hello, I am planning to build my first pc soon, but I am unsure about the drivers that I need to download for them. https://au.pcpartpicker.com/list/8RWjH2 This is the parts that I am planning to get. I did not find a better place to ask this question.
https://linustechtips.com/topic/1429298-drivers-help/
Main PC:
CPU: AMD Ryzen 7 5700X3D | RAM:Corsair LPX 3200 mhz (32GB)
Mobo:ASUS Strix B550-F Wifi | GPU: Gigabyte 9070
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Cooler Master GX III Gold 750
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Crucial 16 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1429298-drivers-help/#findComment-15383613
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1429298-drivers-help/#findComment-15383614
yeah ok. That's true. I meant if OP isn't very tech savvy 🙂
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1429298-drivers-help/#findComment-15383625
