Hi all,
So the sensor panel isn't anything new, just a 5inch raspberry pi screen off amazon and aida64 layout but I wanted to create a bezel to make it appear a bit less temporary and to hide the hdmi and power cables that are routes above. Case is an 011d So no psu basement window which is where most people install them.
I mounted the screen over the Der Bauer logo section using some small rare earth magnets and then created the bezel from some 2mm black acrylic I had lying around around carbon fibre effect vinyl.
Still working on tweaking my screen layout as only got it at the weekend but so far pretty pleased with it!
I have also filled in a few other sections of the case with carbon fibre trim pieces, just to cover some of the various small gaps etc.
Hope you like it!20220502_121246.thumb.jpg.ded830b7f28673ca59b8a8a68a156cf1.jpg20220502_121236.thumb.jpg.ae706f184ca23c27404c28583db5d24e.jpgIMG-20220316-WA0016.thumb.jpeg.3e062a7cd4f6831577436f01a9289fa9.jpegIMG-20220316-WA0018.thumb.jpeg.8b1ad7b90da9f5209c7b0b4ee60e9a5e.jpegIMG-20220316-WA0020.thumb.jpeg.fed3ab22ea6dd1ab92abaa51bcb87db1.jpeg
https://linustechtips.com/topic/1428678-5inch-sensor-panel-bezel/
