Best airflow?
Solved by Ralfi,
6 hours ago, Thejeti said:I was wondering if its ok to change one of the top to be intake(the right one)? That will create a positive pressure right?
Sure, but you could also create positive pressure by increasing the RPM of the two intakes so they bring in more air than the three exhaust fans output. This may increase noise though.
But it may be better for your CPU if you turn that fan around as you’ll not only get the positive pressure you want, but there will be more cool air pushed to the CPU fan, so you may be able to turn the RPM down for at least 2 of your 3 intake fans (for light to medium workloads anyway).
But if noise is no issue, then don’t worry about changing RPM/fan curves.
