Fan controller keeps shutting off
Go to solution Solved by APopester,
problem fixed, MSI center - features- game mode - shut off - fixes the problem
Every time I launch a specific game (fortnite) it seems to shut off my msi afterburner fan controller , and keeps the fans at idle (40%) even though it’s at higher temps I have a msi Nvidia GeForce rtx 3080 Suprim x 10gb it didn’t used to do this , and while the game is running I try to go in and manually set the fan to a higher % but it overides it and puts it right back to 40% regardless of what I do, u less I close out of the game completely then everything is fine
https://linustechtips.com/topic/1426639-fan-controller-keeps-shutting-off/
