So i've brought a new 16gb kit of memory to go with my existing memory i was running windows 11 at the time and the system ran fine for a week then my machine started to blue screen either daily or on repeat so i went back to windows 10 nothing changed and so i pulled the new ram and it was fine. so i try to do memtest86 and there's definitely errors showing up聽 but is there a was to fix theses errors聽 or any avenue to take since warranty is over with the store 馃槥
275624686_386273796659519_733025832579205212_n.thumb.jpg.72a50826fb2836a01a2a65161cfdab36.jpg
https://linustechtips.com/topic/1425903-anyway-to-fix-errors-on-memory/
if XMP is on, you need to turn it off before determining if ram is faulty.
XMP is an overclock and not always stable.
1 hour ago, MrDJSilva said:
i've tried it with both XMP on and off same issues 馃槥
have you tested with only the new memory installed?
