Help with windows 10 installation problem
Solved by drdrewnatic,
4 hours ago, Dualboi said:ok i tried this and it came back with diskpart has encountered an error: the request could not be performed because I/0 device error.
see the systems log for more info
Hmmmmm. Do you think that you could record your screen (or at least take a picture) on every step of the installation process. From the "Install Now" button, to your error. I just want to see what the process is. Could I also have the make and model of the drive? I know you mentioned 1tb nvme, but I never got details.
