16 minutes ago, Anjani said:
So, I have Intel Core i7 11700f.. And the cooler is deepcool assassin 3.. Cpu consumes upto 195W, at 77C running power max stress test.. Deepcool assassin 3 tdp is 280W... I want to know how much power can cpu cooler sustain at cpu thermal throttling
11th gen intel was reallllllly bad with power consumption. It was their worst generation of all time, and it's not even close. That being said, it is not a bad cpu at all, actually it is quite good. Have you tried undervolting/lowering the power limits? Thankfully, you don't have a k chip, so it shouldn't use as much power out of the box.
CPU-AMD Ryzen 7 7800X3D GPU- Gigabyte WindForce SFF RTX 5070ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE- 2TB Samsung 990 Pro PCIE4 NVME x2 PSU-Corsair RM1000x Shift COOLING-Lian Li GA II Lite 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-Samsung G61 QD-OLED 1440p 240hz +Gigabyte G24F 1080p 180hz PERIPHERALSVaxee XE-S+Padsmith Crucible Mousepad+Monsgeek M1 V5 TMR+Autonomous ErgoChair+ AUDIO-Audient iD4 Mk II + Rode NTH100
Like all coolers, the amount of heat it can remove is dependent on the ambient room temperature and case airflow.
If you're at 77C at 195W, then you're doing well. The 11700F is going to be performing at its maximum at that temperature - it will throttle at 100C. Since the CPU is not a K SKU, you cannot overclock it, so if it's reaching the rated all-core speed, then you've achieved maximum performance.
