Budget (including currency): HKD$15000
Country: China- HKSAR
Going to buy this in 2 days.
Games, programs or workloads that it will be used for: Gaming, bit of streaming, recording and editing
I got this for now, need some recommendations for a case and someone to check if this is good I guess?
https://pcpartpicker.com/list/hqgYgb
MANN IM DEADDDDD
https://linustechtips.com/topic/1424882-my-first-build/
Maybe the Core i5-12490F Black edition?
Cheaper SOYO or MAXSUN boards?
Consider 32gb of ram.
3060ti or 3080?
850w is borderline overkill
You don't need to buy windows 11 for full retail price.
As for cases anything with a mesh front for good airflow.
https://linustechtips.com/topic/1424882-my-first-build/#findComment-15352206
3060ti or 3080?
https://pcpartpicker.com/list/6CMGqm
heres the improved version according to your recommendations, would this be good?
MANN IM DEADDDDD
https://linustechtips.com/topic/1424882-my-first-build/#findComment-15352726
No, if you dont get a motherboard with built in wifi you need to look where the wifi card will be installed. You wont want it too close to the GPU fans, ATX motherboards are recommended in that instance.
https://linustechtips.com/topic/1424882-my-first-build/#findComment-15353323
Ok, thanks
MANN IM DEADDDDD
https://linustechtips.com/topic/1424882-my-first-build/#findComment-15354671
