Budget (including currency): £550
Country: England
Games, programs or workloads that it will be used for: Minecraft with shaders, Fortnite, warface, rocket league, roblox
Is this parts list ok (p.s. I can't upgrade any parts to parts that are a higher price, only similar price or lower price):
CPU- i5 12400f (£161)
MB- AsRock H610M HDV (£73)
RAM- Crucial Ballistix 16GB DDR4 3200 CL16 (£57)
SSD- PNY CS900 480GB (£39)
GPU- GTX 1650 Super (£130)
Case- IONZ Gamer Edition Mesh Front (£40)
PSU- Seasonic Core GC 650W 80+ Gold (£53)
Total- £554 (£4 over budget, but it's fine)
The PSU is from the PSU tier list (mid tier), the case is from ScatterVolt's $500 PC Build, and everything else I have found and researched myself.
Note- I have already bought the GPU
Edited by Overpowered66
https://linustechtips.com/topic/1424709-parts-list/
yeah this part list seems fine for your need
"Freedom is the right of all sentient beings"
If my comment helped you please mark it as solution. Refresh before you reply, I edit comments often.
Current PC Spec
CPU: AMD Ryzen 5 3600
CPU Cooler: Scythe Mugen 5
Motherboard: MSI B550 Tomahawk
RAM: XPG D10 White 2x8GB 3200 CL16
GPU: EVGA RTX 3060 Ti XC
Storages: 1x512GB Intel 760P M.2 NVME(boot drive)
1x2TB Umax M1500 Gen4 M.2 NVME(Game storage)
1x1TB Adata SU800 Ultiamte 2.5 inch Sata3 SSD(Game storage)
1x3TB Toshiba 7200RPM CMR drive
Case: Lian Li Lancool II Mesh
PSU: Seasonic Focus GX-850
Keyboard: Ducky Zero 3108 Cherry MX red
Mouse: Logitech G603 LightSpeed
Headphone: Audio-Technica ATH-M20x
Microphone: AVerMedia AM310
Flight stick: Thrustmaster T16000M FCS 3 pack
My Steam Profile (from SteamDB)
  • Value: $308
  • Games owned: 229
  • Games played: 163 (71%)
  • Hours on record: 4,976.9h
https://linustechtips.com/topic/1424709-parts-list/#findComment-15350902
11 minutes ago, Somerandomtechyboi said:
Can you swap the psu to a txm 750w gold?
You didnt really give prices for each of the parts so how the hell are we gonna be able to reccomend anything
Sorry about that, I have added the prices in. And no, I cannot swap the PSU to txm 750W, it's £25 more expensive. If you want, I can give you a list of all of the power supplies that have enough wattage and are not too expensive.
https://linustechtips.com/topic/1424709-parts-list/#findComment-15350916
Sure, core gc is a lower end gold psu so there might be something better thats still in its pricerange
https://linustechtips.com/topic/1424709-parts-list/#findComment-15350935
The list gets quite long to write here, so would you be able to go to PCPartpicker UK, go to Power Supplies and add these two filters: Price- £0 to £55, Wattage- 550W to 2000W, then all of the possible power supplies will be there. Or just follow this link
https://linustechtips.com/topic/1424709-parts-list/#findComment-15350964
the only thing i'd change in this list is change it to a B660 motherboard with VRM heatsink
Current PC Spec
  • Value: $308
  • Games owned: 229
https://linustechtips.com/topic/1424709-parts-list/#findComment-15351089
3 minutes ago, Overpowered66 said:
No, it's over budget, I'm already a bit over so I can't use this, only a PSU from the PCPartpicker link I gave you
Honestly its not that much over that seasonic while being 750w which futureproofs it and hence saves money in the long run since you wont have to buy a new psu if you decide to do a massive upgrade in the future
https://linustechtips.com/topic/1424709-parts-list/#findComment-15351096
As I said, I cannot upgrade any parts for parts that are a higher price, only similar price and/or lower price
https://linustechtips.com/topic/1424709-parts-list/#findComment-15351124
