Pc air pressure
Solved by g0ated,
2 minutes ago, WereCat said:Not sure what you mean by "affect components".
It won't affect anything besides dust buildup and temperatures.
Whether what you want to do is good idea or not depends on many factors.
Some cases benefit from negative pressure, others don't. Fan RPM matters as well, you can still have slow spinning exhausts and fewer fast spinning intakes and achieve positive pressure, etc...
@WereCat will the Corsair 7000x pc case benefit from negative air pressure?
