Budget (including currency): $1600
Country: USA
Games, programs or workloads that it will be used for: World of Tanks/Warships, Phantasy Star Online 2: New Genesis, and Minecraft with Shaders.
Other details: Already bought the case (Phanteks Enthoo Pro Full Tower) and have an existing wired mouse. I'm saving up, but I'm planning on buying the graphics card within 2 weeks. Going to play at 1920x1080p at 144hz. No ethernet cable, so I have to settle for WiFi compatible boards, sorry.
PCPartPicker Part List: https://pcpartpicker.com/list/H8zrrD
CPU: Intel Core i5-12600K 3.7 GHz 10-Core Processor  ($278.99 @ Adorama)
CPU Cooler: ARCTIC Freezer 34 eSports DUO CPU Cooler  ($51.27 @ Amazon)
Motherboard: MSI MPG Z690 EDGE WIFI DDR4 ATX LGA1700 Motherboard  ($310.57 @ Amazon)
Memory: Silicon Power 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($57.97 @ Amazon)
Storage: HP EX950 512 GB M.2-2280 NVME Solid State Drive  ($65.04 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($47.99 @ Amazon)
Video Card: EVGA GeForce RTX 3060 12 GB XC GAMING Video Card  ($439.98 @ Newegg)
Power Supply: Corsair CXF 650 W 80+ Bronze Certified Fully Modular ATX Power Supply  ($59.99 @ Newegg)
Monitor: AOC 24G2 23.8" 1920x1080 144 Hz Monitor  ($217.00 @ Amazon)
Keyboard: EagleTec KG011 Wired Gaming Keyboard  ($45.99 @ Amazon)
Total: $1574.79
Generated by PCPartPicker 2022-04-10 17:12 EDT-0400
https://linustechtips.com/topic/1423977-pc-build-advice/
Just now, IAmNik said:
I suggest doing atleast a 80+ Gold psu, maybe even bump up to a 750w
80+ rating is not a measure of quality.
650W is definitely enough for the build he's got now. I wouldn't worry about more unless he thinks he'll go to a 3070-class card or above in the near future.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1423977-pc-build-advice/#findComment-15345381
