Help fixing low GPU utilization specifically software recommendations
I run a stress test (port royal and times spy) and my GPU stays around 99% utilization but I play Borderlands 2, Lego Star Wars the Skywalker Saga, Horizon Zero dawn and my gpu utilization will drop as low at 2% 20 fps for no apparent reason in area's. If my fps drops any lower then 20 normally the game will crash.
(Hardware 5600x, 6900xt, B550 Aorus Pro, 32gb 3600mhz ram, 1tb ssd, 1000watt psu Windows 10)
Now im looking to software recommendations or setting recommendations to try before giving up on a game could we make a list here
Example Borderlands 3 I had to change to DirectX 12 mode for my 6900xt and it ran better
Running in borderless windowed mode helped Legos and Borderlands 2 from crashing
Any more recommendations please leave a comment down below
1080p? Try disabling ULPS (Ultra Low Power State).
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Ultra low-power state I am unaware of that. is that in BIOS? is that a Windows thing? Is that a AMD software thing?
And im running 1440p 32inch 165hz (even though my Gigabyte monitor is kind of crap for the specs but that is for another time)
You can do it in the registry editor or in a software like MSI Afterburner.
But, since it's 1440p, it's probably not the case.
Maybe playing with v-sync on? That would cause such issues with a high end GPU.
Chipset drivers from AMD installed? RAM running XMP? Latest bios?
My 32 gb of crucial ballistix 3600mhz cl14 Ram is running on xmp everything in my PC has a basic overclock in the AMD software.
V-sync is off in all games for 2 reasons i should be getting more the 165 fps in most games and 2 my monitor reports to some games that it is a 60hz monitor for some reason.
V-sync does not help I have tried it every time any game has dropped below 60fps when trouble shooting; it doesn't help.
Basically I'm wondering what software could be causing my GPU not to run at full speed or is my GPU malfunctioning but I don't think my GPS is malfunctioning because it runs at 100% utilization and every Benchmark and stability test I run. so is it game optimization or some setting or software i dont know about.
Well, then post all software thats installed currently? Its kinda hard to guess, with so many potential offenders, ya'know?
you coud also just reinstall windows  and not install any software besides games to test…
Also reset CMOS.
-Scott Manley, 2021
