Budget (including currency): 3000AUD
Country:  Australia
Games, programs or workloads that it will be used for: Mostly gaming and watching TV shows and stuff. Games like valorant, minecraft and elden ring, cyberpunk.
Other details: Part list attached, need a good monitor, and idk if these parts are good.
https://linustechtips.com/topic/1422975-first-build-need-help/
I'm not familiar with stores outside the United States, so I apologize in advance if any of these listings are inconvenient: https://au.pcpartpicker.com/list/WfTp2m
While the RGB is different across the board, it will be much easier to control & manage compared to Corsair's iCUE. Your original pairing of a 5600X and 360mm AIO was very overkill, so I went with a solid value high-end air cooler and a faster 12600K. I also managed to squeeze in a 3070 Ti over the 3060, as well as a beefy power supply to keep things quieter. This system will handle CP77 very well & stay quite cool for extended sessions.
the pc guy
https://linustechtips.com/topic/1422975-first-build-need-help/#findComment-15338448
Thankyou. Also do you have any recommendations for a water cooler for the asthetic?
https://linustechtips.com/topic/1422975-first-build-need-help/#findComment-15338760
