low fps after driver install
Solved by KhakiHat,
What kind of graphics card are you using? If you check your settings in some of your games, they might tell you if you are using your actual graphics card or if you are using an integrated graphics driver.
Have you moved around any of your display cables? Like making sure that your display is plugged into your graphics card and not the motherboard instead?
