A WiFi question
Go to solution Solved by DoctorNick,
11 minutes ago, Cr33ps said:
If I used a WiFi range extender with an Cat 6 Ethernet cable connected to it would it be faster than a WiFi card in a PC or would their be barely any difference?
https://www.pccasegear.com/products/48492/tp-link-re205-ac750-dual-band-wifi-range-extender
If what you're asking is if you should connect your pc to a wifi extender via cable then no. If you cant get a cable directly to the router, then get a powerline kit instead. Make sure the port is gigabit and not ethernet.
Quote me for the answer and please Mark As Solution if I solved your problem
https://linustechtips.com/topic/1422607-a-wifi-question/
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1422607-a-wifi-question/#findComment-15335733
If I can't get a cable from the router then would it be better since it would be connected to a 2.5G Gigabit LAN port.
Also what is a powerline kit because I've never heard of it before?
https://linustechtips.com/topic/1422607-a-wifi-question/#findComment-15335737
A powerline adapter essentially turns your house's internal wiring into a ethernet cable (This is a very very very rough explanation)
https://linustechtips.com/topic/1422607-a-wifi-question/#findComment-15335741
The 2.5Gbps link speed will be a waste since the ethernet ports on that extender are only 10/100Mbps.
Plugging into a wireless extender is not the same as physically plugging in to a switch/router or using WiFi to the AP. The extender has some latency due to how it's designed.
Wireless extenders are only good for extending coverage. They will inevitably have slightly slower performance. If you're willing to live with that, place the extender at a decent location where it can obtain a good-enough signal from the primary wireless router.
https://linustechtips.com/topic/1422607-a-wifi-question/#findComment-15335782
