I Have an NVIDIA 770 4G. i have not used it for a few weeks. i was going to attempt to give it a spin again after a few weeks. when i used it last it worked perfectly Fine and as it was supposed to. But
When i plug in the PCI-E Cables from my PSU into the card and turn on the PC it turns on for 0.8 seconds then Turns off then does not turn on again unless i switch the power supply Off for 5 seconds and turn it back on from the back. it persist to do this issue. but with the 1st PCI-E Connector on the graphic Card. when i plug it in and not the broken one it works but does not display as it needs all Pins connected. this same issue happened With my AMD radeon RX 580. i have tried numerous PSU's and computers them selves i still get the same issue.
I managed to get my AMD one working again some how not sure how i did it but its only for work stations now as when i use gaming it cuts off instantly
( Note: Some say its a short with the NVIDIA 770. but i am not convinced as it was in its casing these whole weeks none touched in its Foiling. )
https://linustechtips.com/topic/1421808-graphic-card-issue/
That is an ancient gpu. It might just be dead. Why not just use your 580? It's a way better card.
CPU-AMD Ryzen 7 7800X3D GPU- Gigabyte WindForce SFF RTX 5070ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE- 2TB Samsung 990 Pro PCIE4 NVME x2 PSU-Corsair RM1000x Shift COOLING-Lian Li GA II Lite 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-Samsung G61 QD-OLED 1440p 240hz +Gigabyte G24F 1080p 180hz PERIPHERALSVaxee XE-S+Padsmith Crucible Mousepad+Monsgeek M1 V5 TMR+Autonomous ErgoChair+ AUDIO-Audient iD4 Mk II + Rode NTH100
https://linustechtips.com/topic/1421808-graphic-card-issue/#findComment-15330773
Can't It also had the same issue as the 770 but it works as soon as it launches a game it over heats and cuts out like instant. it won't last to long
https://linustechtips.com/topic/1421808-graphic-card-issue/#findComment-15330776
So you have tried multiple pc's and multiple power supplies? Could you have a faulty power strip or something?
https://linustechtips.com/topic/1421808-graphic-card-issue/#findComment-15330781
I am not sure. i am trying to get answers from others to see if it may relate to an issue. the main Video board looks fine no scratch any where No Missing parts i even verified by looking on a graphic card board online. i use a GT 730 and it works good. same with my quadroFX 540.
https://linustechtips.com/topic/1421808-graphic-card-issue/#findComment-15330788
https://linustechtips.com/topic/1421808-graphic-card-issue/#findComment-15330809
