4 minutes ago, LQgin said:
I would like to know where i can get the fan replacement
eBay is probably your best bet. If you can't find them on there (not unlikely) it's probably a good idea to find a couple 120mm fans and zip tie them onto the heat sink instead.
6 minutes ago, LQgin said:
how do I replace the fans
take apart the entire cooler and put it back together with the new fans. There should be a couple videos on YouTube for how to do that for your specific card. If you do the 120mm method, leave the shroud off and just use the bare heat sink when you reassemble the card and go to zip tie on the new fans.
https://linustechtips.com/topic/1421653-gpu-fan-replacement/#findComment-15329692
1 hour ago, LQgin said:
I have a Zotac Gtx 1070 amp edition card and one of its fan had died, and the other fan is about to spoil as well. I would like to know where i can get the fan replacement and how do I replace the fans.
AliExpress is also a good place to look for fans.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1421653-gpu-fan-replacement/#findComment-15329764
