First Build. Any tips/weaknesses?
Go to solution Solved by Pixelfie,
This 3070 Ti is cheaper and has a better cooler. But since we'll save money you can also get a EVGA RTX 3080 or Asus RX 6900 XT.
Why not get a 2tb 970 Evo Plus? It's as expensive as the 2 SSD's you listed, same amount of storage but it's faster and a sata drive less means less cables.
I don't see any reason to spend €200 on a case. This Corsair 4000D Airflow is just as good and only half the price.
The Z690 Tomahawk Wifi is cheaper and just as good.
1000w is extremely overkill. Get an RM750x or Formula Gold instead.
Also the 12700K is only slightly more expensive, but has an iGPU which could be useful.
And you'll need a CPU cooler.
PCPartPicker Part List
CPU: Intel Core i7-12700K 3.6 GHz 12-Core Processor  (€406.99 @ Mindfactory)
CPU Cooler: NZXT Kraken X73 73.11 CFM Liquid CPU Cooler  (€156.90 @ Amazon Deutschland)
Motherboard: MSI MAG Z690 TOMAHAWK WIFI DDR4 ATX LGA1700 Motherboard  (€270.05 @ Amazon Deutschland)
Memory: Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  (€156.72 @ Amazon Deutschland)
Storage: Samsung 970 EVO Plus 2 TB M.2-2280 NVME Solid State Drive  (€219.06 @ LK-Webservices)
Video Card: Asus GeForce RTX 3070 Ti 8 GB TUF GAMING OC Video Card  (€829.99 @ Amazon Deutschland)
Case: Corsair 4000D Airflow ATX Mid Tower Case  (€98.99 @ Amazon Deutschland)
Power Supply: Corsair RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (€104.92 @ Amazon Deutschland)
Total: €2243.62
Generated by PCPartPicker 2022-03-27 17:30 CEST+0200
Budget (including currency): ~3000€
Country: Germany
Games, programs or workloads that it will be used for: Most Games but also school work
Mainboard: ASUS TUF Gaming Z-690-Plus WIFI D4
NVMe-SSD: Samsung EVO Plus 1TB
SSD: Crucial MX500 1TB
CPU: Intel Core I7 12700KF
PSU: Corsair RM 1000X 80 Plus Gold
RAM: Corsair Vengeance RGB Pro 32GB DDR4
          (2×16GB)
GPU: GigaByte GeForce RTX 3070 TI OC
Case: Corsair 7000D Airflow
Resolution: QHD (1440p), 144hz
Edited by b311auto48
Me being stupid
https://linustechtips.com/topic/1420843-first-build-any-tipsweaknesses/
I'd take a 4TB HDD for secondary storage. 1TB is pretty small nowadays.
Total: €2243.62
