I’m stuck in bios PC was fine all day until I changed my AIO. I grabbed a Corsair H100 elite for ICue compatibility. After installing it the red led for my cpu was on my motherboard. It’s was unresponsive until I clicked the bios button on the back of the motherboard. All hardware was being read the cooler was working and everything. My cpu was acting normal no temp spikes or anything. All my storage drives were showing up and being read but can’t see them when I try to enter the boot menu. I’ve tried running csm but then I get a win32 error. I plugged in a recovery drive wiped my SSDS reinstalled windows. I’m still stuck in bios unless i launch in csm and windows with launch in repair mode then instantly fail. I have installed my old cooler and reached same conclusion. Please help really anxious about this.
https://linustechtips.com/topic/1420794-post-issues/
4 hours ago, Adason said:
May be a dumb question but have you tried reseating your cpu and if you had to remove you ram i would suggest doing those aswell. Also what os are you using?
I am using windows 10 pro I don’t know the update and I have reseated it as I was checking to see if pins were bent. I have taken a ram stick out and still the same thing.
https://linustechtips.com/topic/1420794-post-issues/#findComment-15323770
