For some reason out of the blue my PC started stuttering when I try to play any kind of games, I've watched like 30 YouTube videos and haven't been able to find solution yet. I did pull up task manager and my CPU usage didn't break 20% but my GPU was at 100%.  Still a beginner with computers so any help would be greatly appreciated
CPU Intel(R) Core(TM) i9-10900K
Ram  32gb
GPU NVIDIA Geoforce RTX 2060
Motherboard  ASUS ROG STRIX Z490-E gaming
https://linustechtips.com/topic/1419828-game-stuttering-problems/
Is your GPU at 100% all the time or only when gaming? What are your temperatures/ percentages when gaming as well as idle?
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
Its only while gaming, GPU temp stays around 60-70 degrees Celsius at idle and while gaming its in the mid to high 80s' and the usage at idle sits around 30%.  For my CPU at idle is around 12% usage and stays around 40 degrees Celsius while gaming CPU is around 50 degrees celsius
That is pretty warm for idle GPU temps. It should also be less than 30% at idle just on the desktop, I would run a Virus scan using Malwarebytes and see if that finds anything I had a similar situation to this on a clients computer where no matter if the computer wasn't running a single thing it would stay above 30% GPU usage and his games were performing poorly out of nowhere, he had somehow installed a trojan bitcoin miner. If the malwarebytes scan comes back clean you most likely have an overheating issue with the GPU, what case do you have?
Just now, keggs said:
The case is a NZXT h510 elite
Oof, ok yeah NZXT cases are pretty bad when it comes to thermals the H500 series being the worst. I would still run Malwarebytes to be sure but if anything else is causing your GPU to overheat it's going to be the abysmal airflow of that case. NZXT cases look nice but are some of the worst cases out there in terms of cooling and airflow.
the case is a NZXT h510 elite and it did come back clean
thanks for the help!  I really didn't know much when I first started building it lol its definitely been a journey but is there a case you would recomend?
Theres a couple, I use a  Phanteks P500A Digital for my personal build but the newer Phanteks P360A is super clean. Really any case that is a quality make with a mesh front panel should be good. I've personally built in these three and love them. If you aren't looking for flashy RGB the Fractal Design Meshify C is another solid pick.  If you really like the H510 you could get the H510 Flow, really anything with a mesh front panel is what you need. Solid or glass front panels are a no no.
P500A Digital
https://www.amazon.com/Phanteks-PH-EC500ATG_DBK01-Full-Metal-Mid-Tower-Digital-RGB/dp/B088T3VMKK/ref=asc_df_B088T3VMKK/?tag=hyprod-20&linkCode=df0&hvadid=459641872450&hvpos=&hvnetw=g&hvrand=17899475020703106794&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1026999&hvtargid=pla-983307979087&psc=1
P360A
https://www.amazon.com/Phanteks-PH-EC360ATG_DBK01-Ultra-fine-Performance-Digital-RGB/dp/B08KKF38XV/ref=asc_df_B08KKF38XV/?tag=hyprod-20&linkCode=df0&hvadid=475750632217&hvpos=&hvnetw=g&hvrand=883602639683820746&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1026999&hvtargid=pla-1041168687264&psc=1
Lian Li Lancool II
https://www.amazon.com/Lian-Li-LANCOOL-MESH-RGB-X/dp/B09MLYYT7S/ref=asc_df_B09MLYYT7S/?tag=hyprod-20&linkCode=df0&hvadid=563602091749&hvpos=&hvnetw=g&hvrand=8689466828880109079&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1026999&hvtargid=pla-1569921809699&psc=1
