So I have to buy a new (second hand) GPU. My budget is 465 USD sharp.
My options are:
  1. MSI RTX 2060 Gaming Z TWIN FROZR 7 (the most expensive)
  2. ZOTAC RTX 2060 Twin Fan
  3. Gigabyte RTX 2060 WindForce (I've had that one before, but it turned out to be faulty and fried twice. Unless that's just how Gigabyte is)
  4. Palit RTX 2060 GamingPro
That's pretty much it. There's also EVGA XC, but since it's only one fan configuration I guess it would be pretty loud and hot.
Personally I wanted to get the MSI, but I want to ask for opinions.
So which one would be the best bang for the buck in terms of temps and reliability?
I'd really rather avoid another Gigabyte situation where it just died on me twice and they gave me a refund instead of a replacement for a working card.
Thanks!
https://linustechtips.com/topic/1418049-help-me-choose-a-gpu/
All 5 just RTX 2060s? Honestly id say pick 1 thats the cheapest, unless if you wanna overclock or using an aggressively low fan curve in which its horse race between 1&3.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1418049-help-me-choose-a-gpu/#findComment-15304132
