Budget (including currency): 18000 sek
Country: Sweden
Games, programs or workloads that it will be used for: I’m mostly going to play f1 2021, Apex, some streaming and Forza Horizon 5
Other details I have three monitors 1080 p and 144 hz. I am wondering if this build is good?
https://se.pcpartpicker.com/list/m4mzY9
Graphics card https://www.webhallen.com/se/product/331899-MSI-GeForce-RTX-3060-GAMING-X?channable=0131c36964003333313839393e&gclid=Cj0KCQiAybaRBhDtARIsAIEG3kl2uBPM_s7paqA8_ijN_38V-gA1FaEAG4tpirqATWgNsjYRmDPtatcaArMIEALw_wcB
10sek = 1 usd
https://linustechtips.com/topic/1417828-first-build-thoughts/
The build will work, but could be better.
The motherboard has a front panel USB-C connector. The case does not. You might consider a case like the Meshify 2, Meshify 2 Compact, or Bequiet 500DX.
Have you considered an air tower cooler like the NH-D15 Chromax Black, Dark Rock Pro 4, or NH-U12A Chromax Black instead of an AIO?
An 850W PSU is much more capacity than needed. A 650W unit would be fine.
https://linustechtips.com/topic/1417828-first-build-thoughts/#findComment-15302748
